Clear coating a restored tractor
Daniel Hartzfel
02-15-2005 15:21:55
Does any one ever use clearcoat on a restoration, or do you just use the good old classic green only?
Stuart
02-17-2005 13:37:12
 Re: Clear coating a restored tractor in reply to Daniel Hartzfeld, 02-15-2005 15:21:55
Use 800 grit sand paper of higher
F-I-T
02-15-2005 15:37:19
DH:
I put clear on my 70. I used acrylic enamel paint, and then wet sanded it, then cleared it. I think it turned out pretty nice. I have not cleared over JD synthol enamel. Not use if it is compatable.
It"s on my webpage: www.fboerger.com
Frank
8e3k0
02-16-2005 11:27:11
 Re: Clear coating a restored tractor in reply to F-I-T, 02-15-2005 15:37:19
We have had excellent success with ordinary Deere synthel enamal with hardner and then clear coating. Not the easiest to apply as you have to insure the Deere paint is set up to reduce/ eliminate a chemical reaction before applying the clearcoat (12 to 24 hours ).
We have used this process for approximately 7 - 8 years now and the tractors still maintain their original shine and consistency. Ellis
Henry J
02-16-2005 11:34:55
 Re: Clear coating a restored tractor in reply to 8e3k0, 02-16-2005 11:27:11
8e
I am gonna give the clear coat a try this summer. What grit do you sand the green with before clear?
Also, what brand of clear do you use? I am going to a NAPA paint store at the present.
Thanks
