electrical problem on lights mounted on rear fende
bill donovan
02-15-2005 14:38:26
i am having a problem getting the lights on the rear fenders to work. I have checked everything out and know i do not have a ground. The fenders are isolated from the main body with rubber gromets. When i run a wire back to the main frame the lights work, SO THEY OBVIOUSLY USED THE FRAME for a ground, but i don't know how they did it. It seems funny to lose the ground to both fenders. Can i run a ground wire out to both fenders to fix my problem?
John T
02-15-2005 15:28:25
 Re: electrical problem on lights mounted on rear f in reply to bill donovan, 02-15-2005 14:38:26
Bill, if you wanna use the "fender steel" as a frame ground return path for lights mounted thereon, then, of course, as you already understand, YESSSSS you could run a bonding jumper wire say from a fender mounting bolt thats in good clean paint, rubber and rust free contact with the fender and attach its other end to a frame bolt etc., or else use sheet metal screws to bond the fenders sheet metal and wire to the frame elsewhere.
Assuming the rubber baby buggy bumpers are located between the fenders and axle??? Perhaps an easy way would be to use a jumper wire at one of the mounting bolts with a ring or spade connector at the bolts head to mate with fender steel and another ring or spade wire connector down at the nut to mate with the axle??? So long as the bolt head mates with the fender and the nut the axle (rubber baby buggy bumpers between), you wouldnt even need any jumper wire!!
John T
