Grill bolt removal
Tom/Idaho
02-15-2005 05:31:13
1947 A. Does anyone know where I can get the special tool to remove the grill/shutter bolts. They are 5/16, have a round head with a funny looking slot on the top. A large screw driver does not work very well and the local JD dealer was of no help. Thanks, Tom/Idaho
mike in New Mexico
02-15-2005 16:25:10
 Re: Grill bolt removal in reply to Tom/Idaho, 02-15-2005 05:31:13
Hello ! I bought one from NAPA a year or two ago, they had it in stock, you could check with them- the NAPA # is "M-138" .The best I remenber the cost was $ 8 dollars and change. hope this helps-mike
jdman(MO)
02-15-2005 12:10:29
Using a small tip torch and heating the screw red hot before attempting to remove will make it a lot easier. This esp. applys to the shutter screws.Let screws cool down then use your tool, plus some parts blaster oil. Russ
Jason Z in MO
02-15-2005 11:10:41
Deerely Departed has them... It seems pricey to me, but they do have it. Here is the link.
Link
Tom/Idaho
02-15-2005 09:12:31
Thank you very much for your assistance. I shall begin my quest today to locate one.
Tom/Idaho
Mike M
02-15-2005 06:37:41
When I first encountered these I made one from an old screwdriver ground to fit. I then later found one commerical made from a tool dealer and bought it. They call them clutch head style try some local parts stores like NAPA maybe they can order one in. Not to be confused with the clutz heads you may encounter on the quest for this tool.
jdhbag
02-15-2005 05:58:27
Those bolts are called clutch head bolts. I got a tool from Snap On that works on all of my late model letter series tractors. There are several different sizes and two different types, clutch A and clutch G. Mine is is the clutch A tool #SDM 247 5/16". Either should work,
