41 A carb leaking Clooney, John T, anyone
donwisc
02-14-2005 20:31:13
I am having a terribe time with this dltx 7. I bought this slant dash A and the carb was redone on the bowl threads by Roberts but not finished by them. The needle valve does not leak, the seat gasket does not leak and the float is set to spec.
I even set up a hose and fiting off of the drain plug to check the actual gas level and it is to spec.
I then put my finger over the end of the hose, turn on the gas and gas will soon show up coming along that slot on the right side of the carb out of a hole at the end of the slot. This slot is on the Right side looking into the intake.
Is this hole supposed to be plugged, dont see any threads, Am I getting some siphoning action, Appreciate any thought, probably some thing real simple.
buckeye al
02-15-2005 14:47:19
 Re: 41 A carb leaking Clooney, John T, anyone in reply to donwisc, 02-14-2005 20:31:13
One way to determine if it is the bowl vent (with the carb still on the tractor) is to take a used bowl gasket and break a small section out. Maybe a quarter inch or so. Put the fuel bowl on using this now broken gasket. This positions the bowl & allows you to seal the bottom nut but POSITIVELY and ABSOLUTELY vents the fuel bowl.
Turn on the fuel. If it does not pour out the front as you describe with the broken gasket in place, very likely it is the fuel bowl vent that is plugged and causing the grief! When the fuel bowl vent is plugged, a cushion of air is trapped in the top part of the fuel bowl. With the fuel on & trapped air up there, fuel runs up all of the fuel passageways including the main fuel nozzle well before the fuel bowl is full enough for the float to close the fuel valve.
Repair would be as Duane says.
Happy hunting.
Duane Larson
02-14-2005 21:14:37
donwisc,
First, are you sure it is a DLTX7? That was a brass carb used on the over-top steer GPWT. Your's sounds like it may be a DLTX71 - a cast iron body and bowl, with a choke lever which has a cap over the choke shaft/lever. It was used on the '47 up gas burning A. I believe the slot you are referring to is where the air enters the economizer system. If you can confirm this is the carb you have, we can go from there. If you have a 71 (or it could be a 72 used on the all-fuel engines) - remove the bowl and turn the carb upside down. You should see a brass plug which has a raised notch in the center - this is a bowl vent baffle. It is possible the bowl vent baffles (there is also one underneath the one you see), or the passages in back of them, are plugged. This will lead to siphoning of fuel as the air pressures are not in proper balance. Try to squirt some carb cleaner into the brass baffle and see if you can get it to come out somewhere - the somewhere depends on what kind of carb you have. Let us know what you find.
