1958 JD 420
Liz
02-14-2005 16:11:52
I have a 1958 John Deere 420, engine #M3037T. It runs, we still use it, but have bought another tractor to replace this one. The John Deere is in need of paint, the PTO works, doesn't burn oil, runs on gas, the lift arms work but it does leak hyrdaulic fluid. Tires are fair, no longer any lights on it. My dad changed it over to a 12 volt system years ago when he still owned it. Any idea what it might be worth?
buickanddeere
02-14-2005 19:38:37
 Re: 1958 JD 420 in reply to Liz, 02-14-2005 16:11:52
Which chassis, power steering, float ride seat, spin out rims, live pto, 4 or 5 speed, single or dual rockshaft etc?
Liz
02-16-2005 12:17:14
 Re: 1958 JD 420 in reply to buickanddeere, 02-14-2005 19:38:37
It's a row crop tractor, adjustable width on front and rear wheels, no power steering, 5 speed, no live pto, no float ride seat.
buickanddeere
02-16-2005 16:05:28
 Re: 1958 JD 420 in reply to Liz, 02-16-2005 12:17:14
Prices vary but and I hesitate to estimate. Depending on everything, several factors besides the tractor it's self. Maybe 1200 to 2500 tops. The missing lights,oil leak, worn tires, 12V conversion and no desirable options other than the 5 speed drop the price. Is that rear axle adjust on spirals welded to the rims or by sliding on the axel? Big $$$ difference there. On the left rockshaft, is there one or two "arms" on that shaft? Any hobby farmers in the area or people with large rural estates? How far are you from Dennis Polk Auctions? For $15.00 you can trace the serial number from the Two Cylinder Club. I got very lucky and had what we thought was an 840 parts tractor actually be an factory engineering research tractor.
