JD 1010 tractor 710 loader 50 backhoe
Bob Baumgardner
02-14-2005 16:05:43
Looking for some help I have a 1961 1010 tractor(diesl) with a #50 back hoe.When I use the hoe it will only move one cly at a time.You can't lift and swing or lift and curl the bucket ie you can't dig with it.No external leaks at clys,full of fluid,I resealed control body(cessna) if you dead head the controls it will stall the engine so I beleive the pump has enough pressure. any ideas ?? Thanks Bob
TBSCOTT
02-15-2005 09:06:26
 Re: JD 1010 tractor 710 loader 50 backhoe in reply to Bob Baumgardner, 02-14-2005 16:05:43
Bob, I have the exact same combination except my 1010 is a gas. Did you just get this or have you had it a while. Did this problem just start? It might be the valve has been replaced with the wrong one. On mine I can bring in the dipper stick, raise the main boom and swing at the same time.
Bob Baumgardner
02-15-2005 15:03:29
 Re: JD 1010 tractor 710 loader 50 backhoe in reply to TBSCOTT, 02-15-2005 09:06:26
Hello,Thanks for asking TBScott Just bought this 1010 it has been sitting for a couple of years and the other owner stopped useing it because of a fluid leak at the controls so I resealed them with oem cessna parts no leaks now ? Bob
