830 jd pto
Ron Sharpe
02-14-2005 15:21:48
I am having trouble stopping my pto shaft from turning. I have adjusted the yoke back until it stops turning, and it works for a while but then it starts to turn again. Is there some thing else I should be doing?
Mike M
02-15-2005 05:38:43
 Re: 830 jd pto in reply to Ron Sharpe, 02-14-2005 15:21:48
Makes sure your rear end oil 90W isn't getting into your pto unit 10W. Too heavy of oil will make them drag worse.
buickanddeere
02-14-2005 15:33:00
Have you opened the plug port and adjusted the clutch plate clearances internally?
Ron Sharpe
02-14-2005 17:06:18
 Re: 830 jd pto in reply to buickanddeere, 02-14-2005 15:33:00
No I havent yet .I thought that was only to make the clutch grab harder so it wouldn,t slip. I have no problem in that area I just cant get it to stop, unles I hold back on the lever. What should I do?
buickanddeere
02-14-2005 19:44:29
 Re: 830 jd pto in reply to Ron Sharpe, 02-14-2005 17:06:18
The presure plate/clutch plate clearances have to be set inside. Adjusting the external clevis won't do it alone. Have to loosen and spin the collar while setting the gap with a 3/32 rod if memory serves correctly. Clutch and brake travel are related but different. Setting the clutch clearances a wee bit closer doesn't make it engage any tighter either. The picture and instructions in the operator's manual is better than just a 1000 words trying to explain how.
