Johnny Popper Choked???
5th Wheel
02-14-2005 11:45:05
If you are facing the carb on the fuel inlet side, which direction is full choke and which is NO choke?
36BinMN
02-14-2005 13:11:39
 Re: Johnny Popper Choked??? in reply to 5th Wheel, 02-14-2005 11:45:05
Hi 5TH If I may throw one more element in here!! I have a 36B Hand start and the choke is closed if you turn it counter clockwise (DLTX 10 carb) ON my 40A Hand start the choke is closed when you turn it clockwise. I don't remember the carb model on though. Good Luck!!
Duane Larson
02-14-2005 12:44:36
5th Wheel,
On a DLTX Marvel Schebler carburetor, if you look closely at the location where the choke lever is attached to the choke shaft you will find a stamped-in line on the lever. This line is parallel with the choke plate. This makes it easy to tell the position of the choke. For the DLTX67-73 used on styled A's and B's from '47 on the joint of the lever and shaft is not visible, but those are rather obvious anyway, as is the choke position on two barrel carbs.
F-I-T
02-14-2005 12:18:58
5th:
My experience has been that the choke rod (if it's one that goes to the dash) is pulled out for choke and pushed in for off-choke.
It is different on a hand start carb where forward is choke (at least it's that way on my "H").
Frank
1945 A
02-14-2005 12:15:49
Choke is closed when turned toward the driver"s seat----open when turned toward the radiator.
You might want to take the air inlet off to make sure the butterfly is actually moving as you turn the choke....
5th Wheel
02-14-2005 12:40:01
 Re: Johnny Popper Choked??? in reply to 1945 A, 02-14-2005 12:15:49
Thanks, I have never had an old deere till now and the guy that I bought it from said that it was just the opposite, I tried it that way and kept flooding. I was just guessing but figured that he had told me bass ackwards.
