G throttle lever
Jak
02-14-2005 10:04:59
The lever is broken off and the only thing left is the round piece on the swiveling shaft with the spring underneath.The collar won't come off the shaft even with the bolt out.Will I have to take the steering shaft out and remove the brackets?I don't want to break anything beating on it,these G's are getting hard to find parts for.Thanks for any help.Jack(TN).
toot
02-14-2005 11:40:52
 Re: G throttle lever in reply to Jak, 02-14-2005 10:04:59
Do we have another G now Jak? Hopefully? Do like Mark said. Have had to do this to many. Remember, I believe that style of throttle lever is the same on the A, B, G"s.
jak
02-14-2005 11:47:23
 Re: G throttle lever in reply to toot, 02-14-2005 11:40:52
I am working on restoring it for another gentleman and was moving right along until now.We'll break out the ole"Red Wrench" now.I'll have me another G one day Toot.You ought to bring some of your green ones to Dresden May 7th.
Maark
02-14-2005 10:27:21
Heat the area that is left with a torch red hot. Tap down on the throttle shaft when it cools.Should come right off.
Jeff Oliver
02-14-2005 10:26:44
Want me to bring a small gear puller and try that? If not red tip wrench might get it :) call my cell and leave me a message if ya want me to bring one.
Jak
02-14-2005 11:49:08
 Re: G throttle lever in reply to Jeff Oliver, 02-14-2005 10:26:44
Jeff there is no where to get a puller on it,it will have to be heated I guess.We may have to get the little torch set over there.Thanks
