Darn Felts
Walter Squires
02-14-2005 07:45:48
This weekend I put the finals together on the 'H', What a chore seting the preload on the berarings but the thing that really gave me fits was the outter felts, they were so tight in the housing they wanted to spin the the retainer on the axle instead of turn on the retainer, I finaly had to shim the retainers on the axle with a strip of paper to tighten them up so they would'nt spin, I tried grease, soaking them in oil you name it, by the way these were orig. JD felts.
Any one else had problem? sure is hard on a persons blood pressure.
Pat Browning
02-14-2005 11:15:35
 Re: Darn Felts in reply to Walter Squires, 02-14-2005 07:45:48
Here's a new procedure that makes the bearing load adjustments without having the felt in play, and when the shim value is established, the felt washers are installed. Much better (PatB).
Bearing Load Adjustment -- Mount reworked subassemblies to tractor (May 15, 1939 Service Bulletin).
The rear axles are carried on tapered roller bearings, which should be checked and kept adjusted.
To adjust roller bearings, jack up the rear end of tractor and remove drive wheel, rear axle dust excluder, outer bearing cover and felt washer. Next, loosen all except the top cap screw holding the rear axle housing to case until only a very slight tension is exerted by the lock-washers.
Replace outer bearing cover and shims, draw up cap screws evenly until outer bearing cover is tight.
If rear axle housing pulls away from transmission case at the bottom, add one 0.005" shim at a time until housing does not pull away from case. (Note: Bottom cap screw in rear axle housing must be drawn up snug each time bearing cover is removed.)
Replace outer bearing felt and dust excluder and tighten all cap screws.
Reinstall rear drive wheel. ++++
Walter Squires
02-14-2005 13:54:45
 Re: Darn Felts in reply to Pat Browning, 02-14-2005 11:15:35
Pat, That is exactly the way I did it, still a real pain in the butt.
Pat Browning
02-14-2005 15:24:33
 Re: Darn Felts in reply to Walter Squires, 02-14-2005 13:54:45
Yes indeed -- it's not pleasant. On the brighter side, once you have it done right, there's no need to be concerned for many, many hours! Thanks for the reply. Is our H doing OK for you otherwise? So Long (PatB)
Mike M
02-14-2005 09:29:04
I have noticed that some of these parts from JD now don't "fit and wear like the originals" I had some trouble with the felt retainers on the front wheels of a model MT . They made the outer flange so big the wheel would not go on without hitting the dust shields. I had to put the new parts in a lathe and cut the flange down to the size of my originals.
