pluming into 4020 hydraulics to add a loader
Bill Leenerman
02-13-2005 19:27:31
I want to use a loader on my 66 4020 powershift without using the remotes on the rear. How do I plumb into the existing hydraulics to do this?
Thanks in advance.
4020dt
02-14-2005 19:16:43
 Re: pluming into 4020 hydraulics to add a loader in reply to Bill Leenerman, 02-13-2005 19:27:31
The part # for that return port filter cover is AT30197 , that is the # from my 48 loader paers book in 1972 . Put one on the 2020 - 48 loader when it was new . Also have one on my 3020 - 148 loader and one on the 4020 , use it for hydraulic sprayer pump and hyd drives on mixmill augers . My 30-4020's are powershift also , I have them hooked up like mentioned , "T" into line in front of brake pedals return into filter . Powershift has two filters , put ported cover in rear filter , I think it will only fit threre though . I have never heard of a restrictor though , I would think you would want all the flow you can get , seems like it never is fast enough to me , but that's me .
4020je
03-04-2005 11:09:01
 Re: pluming into 4020 hydraulics to add a loader in reply to 4020dt, 02-14-2005 19:16:43
Would this work with a syncro-range. My mom has a 4020 syncro with a loader and both SVC"s are used and I was wondering if the same procedure would work. We would really like to get away from the svc"s
Pete/ME
02-14-2005 02:49:30
Seems like this comes up every six months or so, which is good, because when I did my 4020 the advice really helped when I rigged up a set of remotes for my backhoe to bypass the SCV's. First look in front of the brake pedal and "T" into the larger of the lines and run a hyd. hose under the floor board to the rear. Then get a filter cover with a 1/2" port (a good parts guy at deere can tell you what number...I forget the # and $, but it wasn't too much or find a used one.) Then run another line from there back. I fabricated a bracket that bolted on the axle casting that held the lines with quick couplings. Works slick.
Gerald J.
02-14-2005 07:02:41
 Re: pluming into 4020 hydraulics to add a loader in reply to Pete/ME, 02-14-2005 02:49:30
I like adding a flow restrictor valve to the pressure line for the loader so I don't have to feather 21 gpm going to a 2.5" cylinder and makes the loader (or backhoe) jumpy.
They told me that cover with the lapped hole (about 1" o-ring) was first made for the 2640 so look for that on the 2640 parts computer list.
Gerald J.
