John Deere 530 engine miss
Bill R
02-13-2005 18:21:52
Got a 530 that likes to not fire on the right hand cylinder when on low idle. High speed is fine. Heres whats been done. valve job with new guides, valves were good, of course all new manifold (no cracks) gaskets, oil bath serviced, cap, rotor, points, condensor, wires, plugs, carb been cleaned couple times. If you pull the choke a little it will pick up the other cylinder, or if you pull the wire of the left side, the cylinder that misses will run fine by itself (without choke). One test seems to discount the carb, and the other seems to discount ignition. Usually I can clean the carb and tune the ignition and they'll run great, but this one is just giving me troubles. Any ideas? Thanks in advance.
Prairiedeere
02-13-2005 19:29:18
 Re: John Deere 530 engine miss in reply to Bill R, 02-13-2005 18:21:52
I was just working on my 530 today and I have about the same problem that I need help with. When I start the tractor it runs on one and then after it warms up it runs on both and sounds fine. I have cleaned the plugs and both are getting fire to them (D-16 plugs ?). I can take the one out on the flywheel side and the tractor will run, take the one out on the clutch side and will not run. What could this be? Need new plugs and wires? Thanks
Prairiedeere
02-13-2005 19:25:56
John51
02-14-2005 05:14:22
 Re: John Deere 530 engine miss in reply to Prairiedeere, 02-13-2005 19:25:56
Use new plugs, much hotter than your D-16. I now use Autolite 388. Unless you really use the tractor hard you can't put too hot a plug in it.
