1950 B starting/electrical trouble
Dean Lydey
02-13-2005 12:19:17
When my B doesn't instantly come to life the starter turns the engine over and then growns. I release the button and try again. Recently I've had a dead battery when I leave the tractor sit for a week. I replaced the battery and we're off and running. This past Saturday my battery was dead again after sitting a week. I jump started and we're off to cut firewood. In the woods after a few minutes of idle the tractor simply dies. I try the starter 2 times with the grown. The 3rd try there's nothing. It's as though the started button isn't even pushed. How involved is changing the starter and starter button? It almost seems between the battery issue and the started button that I might have an electrical problem. Any advice?
Thanks
John T
02-13-2005 16:04:45
 Re: 1950 B starting/electrical trouble in reply to Dean Lydey, 02-13-2005 12:19:17
Dean, Although you could have some starter and/or solenoid problems, I wouldnt be in any hurry to remove the starter just yet if it were mine, before I did some other electrical troubleshooting. If its a 6 volt, they dont spin that engine over rapidly like a washing machine even if all's in good shape you know. You may just need a new battery and/or some cable n connection work, plus it sounds like maybe a lil charging system work if she discharges when setting, but that also could simply be a bad battery (like a shorted or bad cell). Other minor problems may be the solenoid or its wiring or connections are bad or theres a bad ground or connection at the switch or solenoid. The starters mechanical drive might also be sticking n hanging into the flywheel. You may wanna insure the belts good n tight and the Gen has a good ground if shes not charging properly !!!!! !
Check the easy simple things first like the belt and condition of the battery and/or its rating and its cables (see below) then the wiring connections and grounds at the switch and if the battery ground and cables are all good.
1) First, and especially if shes still 6 volt, insure theres electrolyte above all the plates and that no cells exhibit a gray or milky appearance which can mean a bad cell. Next, have your battery load tested at a local shop. On 6 volt, I recommend the biggest heaviest highest rated battery (CCA or amp/hrs) that will physically fit in the compartment.
2) On 6 volt, I HIGHLY RECOMMEND at least 00 Gauge Battery cables. Small wimpy ones drop excess voltage and cause slow cranking.
3) Next thing I would do is remove, clean n wire brush, and reattach each n every battery n starter n ground cable ends as poor connections develop heat n resistive carbon causing poor cranking.
4) Another possibiltiy if the battery ground cable is attached to rusty sheet metal like seat or battery boxes etc., is to run a good 00 Gauge ground wire more direct to a good solid non sheet metal frame member bolt.
5) NOWWWWW WWWW if the battery is good and well charged (passes a load test),,,,,all good clean rust n carbon free connections,,,,, ,,,00 gauge cables and a good to frame (not rusty sheet metal) ground,,,,, ,,,, if she still cranks slowly there could indeed finally be a starter orrrrr rrr a solenoid orrrrr rrrr an engine problem causing hard cranking????? ??
6) If when the starter is engaged the lights dim wayyyyy y down and/or the battery voltage drops drastically (and all else above is good) then I suspect more of a starter problem. HOWEVER, if she dont crank well but the lights dont dim much or battery voltage drop much, it could be a bad solenoid.
7) That slow discharge could be a bad battery or theres a minor short in the wiring. If she stays up fine with the battery disconnected then I suspect a short in the wirign and/or a cutout relay problem, HOWEVER, if she still runs down even when disconnected, I suspect a bad battery.
QUESTIONS Does it have a working ammeter?? Show any charge or discharge when running?? When you shut her off, does the ammeter swing to discharge n sit there?? If so, the cutout relay may be bad. Do you know if it has the simple 2 wire cutout relay (on the Gen) and a working light switch field controller or a full fledged 3 or 4 wire Volate Regulator???
Have the battery tested,,,,, ,,insure the belt is good n tight,,,,, ,,try n see if she runs the battery down even if disconnected,,,,, ,,,, and let me know if she ever charges,,,,, ,,,, and if its a 2 wire cutout relay or a 3 or 4 wire VR on the Gen and we will proceed from there. Many got changed over the years so I cant say what you currently have.
Lemme know, good luck n God Bless
John T Nordhoff in Indiana
Dean Lydey
02-14-2005 04:15:06
 Re: 1950 B starting/electrical trouble in reply to John T, 02-13-2005 16:04:45
John,
Thanks for the very thorough response. I have replaced the battery. I replaced what was in the battery box, a 12 volt battery. I assume this means I have a 12 volt system? The positive terminal is connected to the battery box and the negative does fish down inside some conduit to the motor area. I assume this backwards arrangement is correct. I will find a more robust connection for the ground instead of sheetmetal. The other gages seem to work, but frankly I haven't noticed any movement in the ammeter. My lights don't work, that's a project for this summer. I'll work throught the suggestions you've provided.
Is this backwards positive/negative thing correct? I'm not an electrician and just replaced what I saw. Does the 12 volt battery change any of your recommendations? Can a 12 volt battery operate 6 volt system?
Thanks,
For your help.
Dean
