Cause of blue smoke from pulley on 49 B??
RonT in TX
02-13-2005 09:29:37
I have a 49 B that has blue smoke coming out of pulley area. Is this because of bad rings or does the ventilator pump have something to with causing this to occur? I have not done replaced any of the rings since I bought the B a year ago.
Goodwrench
02-13-2005 15:45:26
 Re: Cause of blue smoke from pulley on 49 B?? in reply to RonT in TX, 02-13-2005 09:29:37
Provided the ventilation system is not completely malfunctioning, you probably have a case of blow-by caused by worn rings, set rings ot simply too much cylinder runout. It could be a problem in the clutch, but clutch problems usually 'let you know' in other ways as well.
Perform a compression & leakdown test to better understand where your engine is at. With the smoke you're talking about, you should hear compression whoosh into the crankcase while cranking by hand.
Good luck
