1953 JD 50 Transmission Slips out of 3rd gear
Daniel Hartzfel
02-13-2005 03:36:48
I recently began a resoration project on a JD 50 that my great great uncle purchased new in 1953. For the past 10 years before it was mine, we never used 3rd gear because it would slip out. Any ideas about what would cause this. I would like to gather some info before I start looking into it.
Thanks
deereford
02-13-2005 21:37:36
 Re: 1953 JD 50 Transmission Slips out of 3rd gear in reply to Daniel Hartzfeld, 02-13-2005 03:36:48
Dan, My father purchased a new 50 in Dec. of 1953 and it also slipped out of first and third under heavy load. This tractor came from the factory without the shift lock mechanism that was installed in the later 50"s. JD dealer installed this lock mechanism and solved the problem forever. I now have that tractor and the transmission still works perfectly. deereford
Daniel Hartzfeld
02-14-2005 12:57:19
 Re: 1953 JD 50 Transmission Slips out of 3rd gear in reply to deereford, 02-13-2005 21:37:36
Where do I find one of these lock mechanisms? How complicated is it to install? I am new to this whole restoration stuff.
Jaye Bressler
02-13-2005 17:40:27
Sir,
If your transmission consistanly keeps slipping out of third gear try using second and fourth gear that shouls eliminate your problem
ChuckW
02-13-2005 13:55:09
This is a common problem on the 1/3 position. The upper shaft wears a lot as this is the plowing/discing gear. As the shaft wears it allows the gear to cock to one side and this makes it walk out. You need to renew the upper shaft, find one with less wear. Renew the bearings needed. Also recommend locking shifters, were used in the later 50's as this was a real problem. I have a few parts for this. But you also need to tighten up the lower shaft with new new bearings adjust shims. These tractor were mostly run till they quit with little or no maintenance. If you want the transmission right you will need to renew it. I've done about 6/8 of them and this is what it takes if you want it right.
Stan - Florida
02-13-2005 18:00:49
 Re: 1953 JD 50 Transmission Slips out of 3rd gear in reply to ChuckW, 02-13-2005 13:55:09
Chuck,
You mentioned the 1/3 position. I'm not sure I understand what you mean. Can you expand that a little?
Thanks,
Stan
Stan - Florida
02-13-2005 09:03:52
I can't address the techincal issues, but our '52 B did the same thing in its later years, most likely because that's the gear that was used most and hardest, for plowing, disking, etc.
Wear and tear and old age can take their toll...trust me on that.
Stan
