Interchangable Parts on JD Bs
hope farmer
02-12-2005 19:07:09
This seems like a stupid question even to me, and I'm the one asking it. If I have a 39 B and a 42 B, parts from the 42 should fit the 39 as long as the serial number of the 42 is within the proper range of serial numbers. The serial number is the key, not necessarily the year. Right?
Thanks.
hope farmer
02-13-2005 08:46:09
 Re: Interchangable Parts on JD Bs in reply to hope farmer, 02-12-2005 19:07:09
I have the parts manual PC-330 for the B (Styled) tractor.
If the serial number information posted on this site is even close to accurate, the 42 model B started with a SN of 126345 and ended with a SN 143419.
After reviewing the parts manual, and based on the serial numbers, I see a lot of parts that should interchange between a 39 and a 42. Maybe even some 43s, 44s and 45s. Or am I missing something?
Thanks.
Todd M
02-13-2005 10:26:58
 Re: Interchangable Parts on JD Bs in reply to hope farmer, 02-13-2005 08:46:09
What do you want to interchange? Engine, NO. Trans, NO. Sheetmetal, yes.
What are you looking at to swap???
Todd M
Chris morse
06-14-2005 22:42:51
 Re: Interchangable Parts on JD Bs in reply to Todd M, 02-13-2005 10:26:58
will the gears for the govenor of a 39 work for a 41
JerryBird
02-13-2005 05:30:41
There are almost no parts that will interchange between a 39 and 42 "B".
Pat Browning
02-13-2005 02:31:08
Your answers here are most definitely obtained from the Parts Catalog for the styled Model B. If you have it, scan through the area where you might want to make some interchanges. If you need it, the part number is PC330, available from Deere Pubs (800) 522-7448.
