4010 3pt hitch problem
Tim
02-16-2004 11:42:49
For some reason the 3pt will not raise on my 4010. It works for about 5 minutes right after the tractor is started and then it just rests in the down position. I can hear the motor "work" when I move the 3pt lever to the down position.
It is not low of hyd fluid.
Adam
02-17-2004 21:07:18
 Re: 4010 3pt hitch problem in reply to Tim, 02-16-2004 11:42:49
Sounds like there is a bad internal oil leak. If you can see into the oil fill hole, look for mist in the transmission, this indicated a leak. Also as for working for the first five minutes or so, leaks get worse as oil heats up. I believe that on a 4010 or 20, there is a square plate on the bottom of the rockshaft. I had one that either bolts loosed up or the plate cracked. I was told it was a known probem. Good luck.
