How to move wheels that are rusted to axle
Robert Rudebeck
02-16-2004 11:42:06
Have "720" need to remove wheel from axle, has weight inside needs to be removed. How do you loosen sleeve from axle? So it will move is rusted tight. Have been soaking with B P Blaster. Each weight ways about #200. They are for sale when I get them off.
Ron
02-16-2004 16:47:11
 Re: How to move wheels that are rusted to axle in reply to Robert Rudebeck, 02-16-2004 11:42:06
Take the jack bolts out and put a GOOD amount of penetrant in those holes, put them back in after greasing them good...take the Bigger bolts out.. Heat the hub ( I use an old blow torch, for about 45 minutes, to an hour)..turn the wheel some, to get the penetrant spread around the inside of the hub.. Have a GOOD heavy Punch ready, and hold it on the keyway, and strike it with a 10 lb hammer... it should pop right out..( have the wheel jacked up).. With the wedge removed, you don't have to deal with the rack and pinion.. the wheel will slide off anyway... Ron.. How much for the weights.???..!!!
Mike M
02-16-2004 12:21:14
Maybe try giving the weights away free for removal ?? Get your jack screws working good then put pressure on them pushing out the wedge then smack the end of the axle as hard and straight as you can with a big sledge.
