G throttle handle removal
Jak
02-12-2005 10:23:13
I have a G that has a broken throttle lever on it that doesen't want to come off.I removed the bolt and put some good slickem sauce on it but it still keeps hangin on.I have never had to get one off before but I need to now,any ideas?Thanks
Jeff oliver
02-13-2005 10:41:34
 Re: G throttle handle removal in reply to Jak, 02-12-2005 10:23:13
red tip wrench.... LOL!!!! Seriously I can't remember but I think it is supposed ot slide off of the top. If you don't get it I'll bring a small gear puller from the shop and try that...
Pat Browning
02-12-2005 13:37:06
Hi There -- if it's like other Deeres, that set screw has a long nose on it and goes nearly thru if not all the way thru the vertical rod. Try backing the set screw all the way out and see if that doesn't take do it for you. Good Luck! (PatB)
