410 Stanadyne pump!
Bill From MA
02-12-2005 07:24:53
Ok Guys what do you think?
I was able to start my late 70s 410 the other day but it quit in about 2 minutes! pretty cold outside and first winter start! I have no manual yet so I had to just inspect what I could understand fully! I see a good supply of fuel at the injector pump inlet! The return is dry even when cranking the engine! The fuel pump is moving fuel, so I think the injector pump is no longer turning! Maybe I have sheared a shaft? Maybe condesation in fuel caused a jam in the pump? Maybe I will pull the pump today if it warms up! Going to go look for a JD Dealer now to buy the manuals! Bill From Ma
Bill From MA
02-12-2005 10:04:09
 Re: 410 Stanadyne pump! in reply to Bill From MA, 02-12-2005 07:24:53
Ok, I pulled the timing cover!
inside the window I see what looks like the side of two discs. the front one looks like it is turning just fine! The rear one is not moving! It was hard to tell for sure on the front one as it looked completly smooth. the rear one seems to have many machined areas and would be easy to see if it were turning! So at least maybe I only have an internal pump failure and not a broken shaft anyway! As I have no books I am not positive that the rear disc is surposed to turn anyway?????
Bill
jdemaris
02-12-2005 12:46:33
 Re: 410 Stanadyne pump! in reply to Bill From MA, 02-12-2005 10:04:09
All sounds fine, one is stationary and one turns when the engine turns. You use the window for setting static timing by lining up two marks when #1 cylinder is a TDC of compression stroke. It is also where advance timing is checked by temporarily installing a clear-plastic degreed window in place of the metal cover. The Deere manual is not going to tell you much about the pump that you don't already know. Deere published their injection pump manuals separately, by manufacturor - i.e. & e.g. there is a book for CAV, Roosamaster/Stanadyne, Yanmar, etc., &c. First you have to be sure fuel is getting to the pump. DO NOT check with the hand primer on the fuel pump - it will often give a false reresentation of what the transfer pump does when it is running off the engine's camshaft. Check it with the engine cranking. If you're sure about that, make sure there is 12 volts positive getting to the shut-off solenoid when the ignition is on. You should hear it click whenever the key is first turned on. Also, if not done already, remove the return fuel fitting from the pump. Simply unhooking the return-fuel line is not adequate for testing purposes. The fitting is threaded into the pump cover with 1/16" or 1/8" pipe thread. If you have established that #1 you have fuel getting to the pump, #2 fuel is coming out of the cover when the fitting is removed and engine is cranking, and #3 the fuel solenoid is engergized, than I guess it's time to pull the pump. One note - if the 410 has a single rectangular fuel filter - it's very common for water to sit on the bottom and freeze solid. Then the machine starts, quits, and that's it until you change the filter (or thaw it out and drain it). Sames goes for the older round filters, but the newer rectangular filters will freeze with less water in them.
Bill From MA
02-27-2005 09:01:43
 Re: 410 Stanadyne pump! in reply to jdemaris, 02-12-2005 12:46:33
Ok Pump definitly turning! Fuel at inlet! Return line remains dry! I do not hear fuel sol. click but do have 12 volts there! Time to order SM2045.
Thanks for the info.
Bill F
jdemaris
02-27-2005 10:36:22
 Re: 410 Stanadyne pump! in reply to Bill From MA, 02-27-2005 09:01:43
Just pull the cover off the pump, it's not high-tech. The cover is held on by three little bolts. The electromagnetic fuel control will come off with the cover. You can see it and figure what is going on. It's a ten minute job to replace it.
Bill From MA
02-21-2005 20:01:35
I just recieved the manuals today! $380 for all, they look great and I am glad I purchased them! I did notice they do not break down the Pump at all! Now that I have your advice and the books I will look deeper at the simple things as soon as time and weather permit! Thanks to all for all the help! I will post the results when I can get back to it! Bill From Ma
jdemaris
02-21-2005 20:14:35
 Re: 410 Stanadyne pump! in reply to Bill From MA, 02-21-2005 20:01:35
Injection pump manual from Deere that covers Roosamaster/Stanadyne is SM-2045.
Bill From MA
03-02-2005 06:34:57
 Re: 410 Stanadyne pump! in reply to jdemaris, 02-21-2005 20:14:35
manual ordered! Can't wait to get this one running! Bill
jdemaris
03-02-2005 06:49:04
 Re: 410 Stanadyne pump! in reply to Bill From MA, 03-02-2005 06:34:57
There is one special tool you'll need to get the pump apart. There is one bolt in the pump (cam advance screw) that needs a fluted wrench. Part # 15499.
Bill From MA
03-06-2005 06:23:08
 Re: 410 Stanadyne pump! in reply to jdemaris, 03-02-2005 06:49:04
OK I Removed the pump Shot off sol. cover! Bench tested the sol. very quiet operation but she shifts and holds fine! Everything looked nice and clean also! I re assembled the top of pump!
I noticed the pump was not full of fuel, outside temps hit 40F.
I figured I would try cranking the engine to refill the pump! It took a few minutes in all! Then suddenly it began injecting fuel! We Have smoke! I had it running shortly after!
I guess there was blockage in the pump somewhere! I did preheat this thing for 4 hours with a torpedo heater previously, the entire machine was warm! IF it was Ice that should have done it?
I am going to try and restart it today. The fuel filter was not gelled as I always had good flow to the pump!
Pretty much scared it into working by buying $500 in manuals! Thanks for all the help and the great knowledge! Bill From Ma
jdemaris
02-12-2005 08:32:15
Pull the little rectangular timing window off the side of the pump - held on by two screws. Then crank the engine over and see if the pump is turning.
Bill From MA
02-12-2005 09:39:17
 Re: 410 Stanadyne pump! in reply to jdemaris, 02-12-2005 08:32:15
Thanks I will try that just before I pull the pump off! Just in case! I called for my manuals today but will need to call them back monday when they re open! They did tell me my machine was a 1979 and that it would be a couple weeks anyway to get the manuals! I will post an update if i find anything!
Bill From Ma
