FLATHEAD
FRANK
02-16-2004 10:08:47
I am thinking about putting a flat head on my 1949 JD G could any give me some info about this idea
2 Cylinder
02-16-2004 11:55:14
 Re: FLATHEAD in reply to FRANK , 02-16-2004 10:08:47
I have one that had .090 over pistons that turned 57HP on the dyno. Went to aluminum high compressions .090 over and it turns 68HP. The flat head will give you in the neighborhood of 10HP. The down side to this is you need high octane gas for the 68HP combination. I use my 51 G for tractorpulling only, so I don't mind using the good gas to eliminate the pinging from the real high compression, she does run good though.
FRANK
02-17-2004 17:10:49
 Re: Re: FLATHEAD in reply to 2 Cylinder, 02-16-2004 11:55:14
Thanks for info i was also wondering about intake manifold and tire size
easydoesit
02-18-2004 10:05:25
 Re: Re: Re: FLATHEAD in reply to FRANK, 02-17-2004 17:10:49
Frank, I think the pushrods are shorter when you use a flathead. Easy
