JD 4010 Filters
Corky
02-11-2005 20:46:53
It seems silly to me, but I haven"t found any oil or hydraulic filters on my JD 4010. Where are they located?
billyiron
02-11-2005 21:43:28
 Re: JD 4010 Filters in reply to Corky, 02-11-2005 20:46:53
the engine oil filter is behind a 4-bolt cover on the oil-pan left side of tractor---the hyd-filter is left side of tractor under operator station on transmission-rearend housing,,,,billy
msb
02-12-2005 08:28:56
 Re: JD 4010 Filters in reply to billyiron, 02-11-2005 21:43:28
The hydraulic filter takes a 3/4" wrench and looks like a cast iron can of sorts.You will probably get about a gallon and a half of oil when you remove the filter,so put a bucket under it and the discard the oil.Don't reuse it.There is a gasket(packing) that sometimes sticks to the filter.It goes in the cap.Some people no longer use it,but I still like to.
