2010 diesel starting issue
Kerry
02-11-2005 06:38:30
jdemaris
02-11-2005 18:09:46
 Re: 2010 diesel starting issue in reply to Kerry, 02-11-2005 06:38:30
How did you get the bigger bore diesel sleeves into the smaller bore gas engine block? Did you have the block machined to take the 1/8" bigger sleeves and the larger o-rings? Also, how are you going to keep the crankshaft from flexing and/or breaking under the high compression of a diesel - since the gas block only has three main bearings instead of five? Doesn't seem the engine should last very long unless I'm missing something in what you did. As far as the Roosamaster pumps goes, as long as it is turning, and the shut-off is "on", and fuel can get out of the pump, and fuel is getting IN to the pump, it will pump high-pressure fuel IF the pump is okay. Just taking the return line off the pump won't tell you for sure because the fitting in the pump cover might be plugged. The said fitting might have a check ball in it, but most 2010 applications have a wire instead. If all else fails, take the fitting completely out and then test the pump. Please post and take the mystery out of the diesel parts in the gas block.
Kerry
02-11-2005 18:37:51
 Re: 2010 diesel starting issue in reply to jdemaris, 02-11-2005 18:09:46
It has been a few years since I did that conversion but the block was the same including the mains. Of course it was not set up for a fuel injection pump but a regular gas fuel pump. The machine shop bored the block out to take the diesel liner kit. We used the crank and all internal parts from the old diesel engine in the new converted block. The old block had cracks all around the main bearing areas and was not worth fixing. The gas block was sent to the machine shop by mistake--they just pulled the engine from a 2010 gas tractor and didn't realize their mistake until my machine shop called them. After looking over the two blocks, machine shop recommended just boring out for the new diesel liner kit to fit. It has run very well until now.
Bob
02-11-2005 06:59:12
One thing to check is that the fuel return line must not be restricted, all the way from the fitting in the pump cover, back to the fuel tank.
If the fuel return line is restricted, the high pressure pistons in the injection pump will not return inward and recharge will fuel, so no high pressure fuel delivery will occur.
If you're carefull about some spilled fuel, you can attempt to start it with the fuel return unhooked from the injection pump. If it has not run, though, since the pump has been removed, you'll need to bleed the fuel system. Do you have another tractor and capable help, so you could pull the tractor around safely to bleed the system without all the wear and tear on the starter? Or pull the glow plugs, to relieve compression while cranking it with the starter to bleed it.
Kerry
02-11-2005 16:01:12
 Re: 2010 diesel starting issue in reply to Bob, 02-11-2005 06:59:12
Thanks, I'll check the return line and give that procedure a shot!
