2030
PJB
02-11-2005 04:44:46
I just rebult an engine in a JD 2030. Everything went fine ,but I have to reset the value clearance on the intake and exhaust value. I know you take the cover off that lets you see the mark on the fly wheel..... but how do I turn the engine over slow enough to line the mark up??? The engine is in the tractor. I could turn the engine over with the starter and do one value at a time.....
efi deere
02-13-2005 15:01:25
 Re: 2030 in reply to PJB, 02-11-2005 04:44:46
Take the cap off the clutch housing, on the left side. You can then stick a bar or screwdriver in there and turn the clutch.
Mike M
02-11-2005 05:24:25
Did you put in new conn. rod bolts ? I think this is a must on these engines as they strech.
PJB
02-11-2005 11:07:08
 Re: 2030 in reply to Mike M, 02-11-2005 05:24:25
Yes, I did put new bolts in. I bought the rebuild kit from my JD dealer. I could of bought an after market rebuild kit cheaper ,but I went with the real deal "John Deere" parts. I went with Deere parts just for piece of mind..... .,but for all I know the after market kit could be better.....
Mike M
02-11-2005 12:13:20
 Re: 2030 in reply to PJB, 02-11-2005 11:07:08
The few newer tractors I have done I also used JD parts for the same reason as you.Plus I used to work at a JD dealer and we never really had any problems with them.Aftermarket is not that much cheaper than OEM. JD stays pretty competitive on the common parts.
