Rebuilt a 4020 LP. IT manual said go to 0 degrees and do this and do that. Later on it said set timing to 25 BTDC. I missed that sentence. Worked my cheeks off trying to get that tractor to run right, start and all and couldn't make any progress. Had 2 of the local experts out and they just scratched their heads....everything they usually found to be the problem wasn't. Nobody thought to check the timing. In short, I reread the manual and this time discovered the overlooked sentence. Set the timing properly and no more problems. Don't know about the diesel, but if it doesn't want to crank and run, might look some more. TDC makes for a sluggish engine (any engine) if you have nothing to advance the spark/fuel injection timing. I know of mechanical advance on the distributor of gas engines to do that. Don't know what an injector pump would use if anything. You have to get the bang started before the piston hits the top so that it has had time to get there when needed. Even with a diesel, where you want a cylinder full of hot compressed air then "squirt" it still takes time for the injector pump to know it's time to squirt, squirt, get the fuel to the injector, and the injector to squirt it..... the whole time the crank is still turning; piston is still moving. TDC seems a bit late.....but I dunno. Food for thought. Mark
