JD 2520 Gas Stalling
Pete
02-16-2004 08:20:20
My JD 2520 has a tendency to stall. Generally when in gears 5-8 when going up a hill. Tractor is not being put under heavy load. What happens is it starts to sputter then quits. Any ideas?
John51
02-16-2004 16:12:12
 Re: JD 2520 Gas Stalling in reply to Pete, 02-16-2004 08:20:20
There is an electric solenoid in the carb that shuts off the fuel supply when you turn off the switch. They can go slowly bad and give you fits, shutting off the gas at inconvenient times. Not a cheap fix- very easy to replace but around $140!
old
02-16-2004 09:30:42
Just a guess, low fuel?? or its a carb problem. Check the filters /sediment bowl and check for a good flow out of the bottom of the carb.
