300B Backhoe-good hoe
SteveinCT
02-10-2005 12:23:19
Hi, I have the opportunity to buy a tight '81 300B with almost 4000 hours for a decent price, with a knocking noise in all gear ranges from either the transmission or maybe the final drives. Can someone who has owned a 300B let me know if it's a decent machine and also, if it's the tranny, how hard is it to split and how hard are the parts to find. Thanks a lot, Steve
Jonathan in MA
02-11-2005 04:53:37
 Re: 300B Backhoe-good hoe in reply to SteveinCT, 02-10-2005 12:23:19
Hard to say what the sound is , but occuring in all gears I would tend to lean towards the ring/pinion area, but there are other transmission parts that are also always rotating. That is not a traditional problem area with those, but who knows what someone was doing with it. If its a problem that created/is creating metal shavings or something grinding into the transmission case, then check the hydraulics carefully, as the transmission case is also the hydraulic reservoir. Metal grindings can do bad things to the hydraulic pump!! Check the outer wheel bearings on the rear axle. lift the rear up with the stabilizers and check for movement. There are grease fittings out there that are commonly overlooked. When the bearing fails, it can cause havoc with the planetary drive on the inboard side of the axle, and can make a "cluncking" sound
Henry J
02-10-2005 16:36:12
Steve
I don't know anything about the innerds of that model, but have had a knocking in all gears in a tractor that had a automotive/truck style differential (ring and pinion).
It turned out to be teeth broken off the ring and pinion. Just a thought.
If there is some type of cover you can pull off the rear, which I think might be impossible with a hoe on it, you might try shining a flash light onto the ring gear.
Let us know what it turns out to be if you go for it. Good Luck
ChuckW
02-10-2005 14:16:10
Haven't been inside the rear end on the industrials but people that have say the rear parts are lighter than the agricultural version. Wasn't intented to pull but rather a lot of hyraulics usage. I can't say this is true or not till I've seen for myself.
Mike M
02-10-2005 13:14:04
Is that the one on ebay ? Did you go drive it yet to hear what it does ? Those are good machines and that price looks tempting if I was closer I'd go look for myself. Of course if it is really screwed up inside it could get expensive fast.
SteveinCT
02-10-2005 16:27:11
 Re: 300B Backhoe-good hoe in reply to Mike M, 02-10-2005 13:14:04
I am going to look at it on Saturday. I don't own a Deere, but would be proud to, except for the rumor I hear that the parts are very expensive. Am I wrong? Thanks.
Mike M
02-10-2005 18:54:25
 Re: 300B Backhoe-good hoe in reply to SteveinCT, 02-10-2005 16:27:11
ALL PARTS are expensive ! It pays to shop around on prices some dealers even offer discounts on stock ordered parts.Aftermarket keeps growing bigger and used parts are around. The internet should make finding used stuff easier than ever before. This site is a good starting place.It could be a ring gear because if you dig with the hoe and leave it in park all that jerking around can tear up stuff. It's a good idea to put into neutral after the stabilizers are down for hoe digging.
MH
02-10-2005 12:38:10
I always understood that the 300 was the industrial version of the 1020. So I believe it would be a late sixties early seventies model. (someone correct me if I'm wrong please)
MH
02-10-2005 12:36:55
cannonball
02-11-2005 05:21:13
 Re: 300B Backhoe-good hoe in reply to MH, 02-10-2005 12:36:55
the 300 b was one of the most popular hoe because of its size weighs about 10,000 and is built strong...and yes they go into the 80's ...you could look at parts online..have an old 1973 here..needs motor job..have parts and tech manual....boy enjoyed that machine...have nice day may god bless
