2030 Hyd. lift
Girl Farmer
02-09-2005 20:40:57
2030 John Deere ,problem is lift will raise very slow until you turn the steering wheel, then the lift will raise normally. Any help would be much appreciated (filters & fluid are ok)
Buckeye
02-10-2005 19:21:55
 Re: 2030 Hyd. lift in reply to Girl Farmer, 02-09-2005 20:40:57
I have a 2030 that will not lift at all until you turn the steering wheel. Just a touch and it will jump right up. A retired JD mechanic told me that the problem was caused by a valve in the hydraulic pump.
cannonball
02-11-2005 05:23:48
 Re: 2030 Hyd. lift in reply to Buckeye, 02-10-2005 19:21:55
stroke control valve in pump...have nice day may god bless
John36bn
02-11-2005 04:06:03
Thats probably the priority valve under the RH footrest acting up. It saves hydraulic flow/pressure for steering should there be a hydraulic "situation" somewhere on the tractor. I am no expert so repost and hopefully an expert will respond.
