How to change/replace tire on manure spreader (R-1
LD
02-09-2005 18:11:55
Hi, I bought an old JD manure spreader, ground driven (series R type 1 or could be vice versa...). One of the tires has gone flat and it might run a little better if I repair or replace it . I have absolutely no idea of how to get the darn thing off so I can take it in and get it fixed. There is a cotter pin thru the end of the hub. Is that just for grease or does it hold the wheel on? Keep in mind I"m totally clueless here and could really use your help (detailed directions).
Thanks!!
Laura
Duane Larson
02-10-2005 06:27:55
 Re: How to change/replace tire on manure spreader in reply to LD, 02-09-2005 18:11:55
Laura,
You're on the right track. The parts book shows a pin in notched recesses in a hubcap, and the hubcap screws on. Remove the pin (or in your case apparently a large cotter pin) and unscrew the hub. The wheel should then slide off.
