Battery ground
Al Rose
02-09-2005 17:38:06
Is a 1945 JD G postive or negative ground? Thanks
twopopper
02-09-2005 20:19:42
 Re: Battery ground in reply to Al Rose, 02-09-2005 17:38:06
I have a 1950 A John Deere, has factory generator and starter, it is negative ground. Not sure about the G.
John T
02-10-2005 06:27:15
 Re: Battery ground in reply to twopopper, 02-09-2005 20:19:42
Twopop, Although all 2 bangers were originally Positive ground, that DC Generator can/will still work n charge if reversed to Negative ground and polarized, the ammeter leads have to be reversed so she dont read bass ackwards, however, and perhaps coil leads reversed. Many got reversed if they switched to a GM alternator or electronic ignition or just by accident. If shes not broke dont fix it as they say lol.
John T
CLW
02-09-2005 17:51:50
Would have left the factory pos. ground.
CLW
John T
02-09-2005 17:50:53
Al, ALL 2 cylinder Deeres and even including some of the new generation until they switched to alternators, were originally from the factory wired POSITIVE ground.
John T
mattd
02-09-2005 17:49:59
it originally came from the factory 6 volt positive ground
matt
