John Deere 2150 MFWD
Big Bud
02-09-2005 16:26:50
I bought a JD 2150 and the front wheel is rusted so bad I can"t use it. I went to the dealer and they said it was discontinued. And I would have to buy a different wheel; the problem is I have to buy both the hub and the wheel for both sides. Needless to say that will cost around $1,000. Do yall have any idea where I might be able find a close after market or a used one? Thanks a lot Bud
rockfarmer
02-14-2005 16:11:54
 Re: John Deere 2150 MFWD in reply to Big Bud , 02-09-2005 16:26:50
had the same problem with 2155 mfwd. i bought rw8x24 unpainted rims for use with 9.5-24 tires from re miller tire 4193357010. they may have website. i then ground off the old loops from the bad rims and welded them to the new rims.had to measure quite a bit before grinding off old loops to make sure they would be square and properly spaced on new rims. then painted new rims and used old center dish to mount wheel. total about $250 plus time. could also try gnk armstrong wheels 7128643202. may save you all the work .hope this helps.
