4640 shifts hard
Mark Jankins
02-09-2005 12:34:58
I have a 1981 4640 with 8 speed powershift. My problem is that it shifts very hard, especially from 7th to 8th. Even pushing in the clutch pedal, it jerks the tractor big time. It is even worse if you downshift from 8th to 7th. Some of the other gears are a little rough, but I have been told it's normal for the 8 speed powershift. Any ideas?
Mark
buickanddeere
02-10-2005 08:55:45
 Re: 4640 shifts hard in reply to Mark Jankins, 02-09-2005 12:34:58
Isn't there a flow valve adjustment down on the side of the trans? Higher flow/faster shifts for heavy draft loads to limit clutch slippage/heating. And a less flow for slower softer shifts with a wee bit of give for light work/putting around.
ijl
02-10-2005 10:34:44
 Re: 4640 shifts hard in reply to buickanddeere, 02-10-2005 08:55:45
Buickanddeere... if there is a flow control valve adjustment I would like to know where it is as I have a 4640 with the jerk-o-matic transmission in it too. I Like the tractor,but not the neck snapping jerk when I shift gears.
buickanddeere
02-10-2005 12:21:40
 Re: 4640 shifts hard in reply to ijl, 02-10-2005 10:34:44
Don't know about the large frame rowcrop tractors but the smaller chassis tractors. They have the ajustment on the left side in there by the trans oil filters. The info should be in the operator's manual.
Chris Radake
02-09-2005 21:16:26
Yes that true that reason why shifts so hard on it. that Depend on where you parked on sometime on hills or sometime parks on rocks or woods or something like that. It won't move shift to where you want from it. I drove that before and I used work with it.
Mike@Minn.
02-09-2005 19:05:37
I agree with mattd. I bought my 4440 new in 1982 with power shift. I usually clutch it when I shift so I can control the smoothness of the ride.
G/MAN
02-09-2005 15:37:25
The 8-speeds tend to shift much more roughly than the 15-speeds because they have wider gaps between speeds and used mechanical accumulators. The 15-speed trannies use a nitrogen accumulator that dampens the shift quite a bit, providing it's properly charged. One simple check to make on your 4640 is that the transmission operating pressure is within specs. If it's too high or too low, it can cause them to shift rougher than normal.
mattd
02-09-2005 14:22:42
both my 4640s shift hard from 7 to 8. what i usually do is go about 1700 rpm in 7, then push clutch in throttle down to 1200 shift to 8, then let clutch out. much much smoother. throttle way down push clutch in then downshift 8 to 7. again it is much smoother. i dont know if this is the right way to "fix" it, but its worked for 20 some years.
matt
thurlow
02-09-2005 14:55:50
 Re: 4640 shifts hard in reply to mattd, 02-09-2005 14:22:42
Owned a 4840 for many years; never had any transmission problems although I had to tear into the rear end. Thing would jerk a crick in your neck from day one..... .
