GAS TANK HELP
GERRY G
02-09-2005 08:07:09
IS THERE AN EASY WAY TO CLEAN A GAS TANK ON A H.IT LOOKS LIKE A COATING IS COMING OFF AND IT LOOKS LIKE PEELING PAINT . I DON'T WANT TO TAKE THE TANK OFF THE TRACTOR.
Pat Browning
02-09-2005 08:45:29
 Re: GAS TANK HELP in reply to GERRY G, 02-09-2005 08:07:09
From your write-up, it's hard to understand what's happening. Are you saying that the tank was coated inside with a tank liner at some previous time because of rust and/or leaking and that it is the liner coating that is coming free? As for not wanting to take the tank off the tractor, I stand in complete awe as to how you will rework it otherwise! You need to expand that some.
Now, when and if you DO take the tank/hood assembly off the tractor, I have found a way to do that without having to deal with the muffler installed; just remove the tappet cover vent pipe and exhaust pipe; the steering wheel, front medalion and steering wormshaft -- you now have access to the three cap screws holding the muffler in place. Once they are removed, the muffler can be drawn out the bottom. Reverse the procedure to reinstall. While this don't resolve the tank problem, it sure makes dealing with the tank/hood asembly much easier. (PatB)
Mike M
02-09-2005 09:40:47
 Re: GAS TANK HELP in reply to Pat Browning, 02-09-2005 08:45:29
Come show me how that hood removal trick works. P.S. my H has electric start. When you get here I'll stand on one side and you on the other. I think we can lift it up over the muffler faster than removing it.
Pat Browning
02-09-2005 10:17:23
 Re: GAS TANK HELP in reply to Mike M, 02-09-2005 09:40:47
This is a case where old age & treachery use some enginuity to overcome youth & ignorance. Don't knock it until you've tried it! For electric start, you may also have to drop the generator out of the way! (PatB)
Mike M
02-09-2005 10:55:03
 Re: GAS TANK HELP in reply to Pat Browning, 02-09-2005 10:17:23
Let me put it more bluntly,Takeing that muffler off is going to take longer than just lifting off the hood up over it especially if you have a generator in the way.An H is not that high up or heavy a small step stool and one can even do it alone. Thank You for thinking I'm young. I'm more middle aged now. I've been working on these since I was 13. I've been fighting that sterotype all along and let me tell you that old age does not ALWAYS = wisdom.
Pat Browning
02-09-2005 11:11:56
 Re: GAS TANK HELP in reply to Mike M, 02-09-2005 10:55:03
Mike, I just try to help a little now and then. And should there come a day when, because of fair wear & tear to your shoulders and/or arms, you can no longer lift that high with any skill -- thus risking damage to, say, a really great paint job; perhaps this technique will come in handy. I wish you well on your fuel tank issue. Have a Great Day. (PatB)
Mike M
02-09-2005 12:02:19
 Re: GAS TANK HELP in reply to Pat Browning, 02-09-2005 11:11:56
I have allready used that technique. I was trying to point out that if you had a generator you will not save any agravation by pulling it off before the hood.Those models have that generator crammed packed up under there and very hard to get at the bolts.As with any operation there is usually more than one way to skin a cat. The two we have mentioned I would recommend.I have seen a third that I won't do ! Slit the hood so you can pull it off leaving the steering shaft and muffler in place. This was not a pretty sight.
