4010 12 bolt conversion
hogman_2002
02-08-2005 21:08:19
Who besides John Deere makes a 12 volt conversion kit for my 4010?
Bob
02-09-2005 00:23:33
 Re: 4010 12 bolt conversion in reply to hogman_2002, 02-08-2005 21:08:19
You don't need a "kit", although many tractor parts places have them. A local auto electrical shop could probably fix you up with what you need.
All you need is a 12 Volt starter for a late 4020, and a 12 Volt alternator. Also, usually a 12 Volt "automotive-type" starter solenoid is used along with the starter solenoid to take the load off of the starter and neutral start switches.
I can email you a diagram of the wiring changes that are needed, if you'd like.
That being said, as much as I sometimes hate the Deere 24 Volt systems, after helping many people with their 12 Volt conversions, I've left my early 4020 24 Volt.
For a 12 Volt conversion system to crank the engine was well as the 24 Volt system did, the starter must be in excellant shape, you need 2 high cranking Amps 12 Volt batteries paralleled, and good HEAVY battery cables.
Is your 24 Volt system in real bad shape, so's it's tough to fix, or why are you considering the switch to 12 Volts?
Lois Haglund
02-09-2005 09:31:20
 Re: 4010 12 bolt conversion in reply to Bob, 02-09-2005 00:23:33
I"ve been following your discussion here; would my John Deere 730 Diesel be similar?
There are no "local" tractor mechanics here; I am trying to gather info so that the local mechanics can help me iron out some starting problems... wondering about this 12 vs 24 question....
hogman_2002
02-09-2005 08:39:43
The starter was rebuilt probably 4 years ago, and the generator was rebuilt less than a year ago. Both are in pretty good shape. I have fairly new battery cables that are 2/0. The main problem I'm having is keeping batteries in them and running the lights. Those John Deere batteries just don't last. I was hoping to find a conversion kit for under $500. I may end up buying the one from this site.
Rodney A. Johnson
02-09-2005 08:45:49
 Re: 4010 12 bolt conversion in reply to hogman_2002, 02-09-2005 08:39:43
AES (Ag Electrical Specialists) 1-800-328-7845 in Racine MN set me up with a conversion kit for 415USD a year or so ago for my '64 4020D.
So far I've been very happy with it. Installation was relatively easy. The instructions were good, and everything was tagged.
And the most important thing was I nolonger had to unhook the batteries to keep them from being drained due to current leaks in the starter and/or generator.
