Tips on soundproofing older cabs
GJS
02-08-2005 17:16:59
We have a JD 7700 turbo combine and I will need to do some work on the inside of the cab before the next harvest. I found a kit for the insulation but was wondering if anyone has any tips to quiet it down some. That is the only complaint about it. It's got a cold air conditioner just a little noisy. I know it may be hard with the engine next door but I appreciate any suggestions.
960
02-09-2005 13:23:34
 Re: Tips on soundproofing older cabs in reply to GJS, 02-08-2005 17:16:59
I know your situation. I had a 227 picker then a 74 4400 then a 79 6620 and now a 90 9500 and naturally each was a major step above the previous in operator comfort. The 4400 got so noisy I could not stand it and traded it mainly for that reason. What I found the main sound deadner on the 6620 to be is the foil type heat sheild insulation used as firewall insulation between the cab wall and engine compartment. Rodents and time took thier toll. As in another post make sure all linkage and harness boots are in place. When mine got louder I double layered the insulation on firewall and it helped greatly. My father-in-law still has a 7700 that is still an impressive machine today. Good luck.
G./MAN
02-09-2005 07:32:23
John and Ray are exactly right - getting rid of noise that is "transmitted" into the cab from outside is the most important step. Any metal-to-metal contact is going to increase noise.
R. John Johnson
02-08-2005 21:10:46
Sound proofing a cab is a two stage process. First you must isolate the cab from chassis borne vibration (noise). This is the job of the rubber isolators. If some component contacts the frame and the cab in a manner that can transmit vibrational energy it will defeat the job of the isolators. Make sure there is no such object.
Ray gave you good advise. If a component mounted solid to the cab is vibrating, the isolators don't mean a thing.
The second stage is to line the cab with sound absorbing material. The lining in the cab serves two purposes. First it closes up small openings. A small hole will let in a lot of noise. Think about how much louder the cab gets when you crack the door. The second job of the lining is to absorb structure and air borne vibration. Foam that has deteriorated will not be able to do this very well.
The majority of silencing a cab is done by isolating it from the structure. The lining cannot do it by itself.
I hope this helps
John
RayP(MI)
02-08-2005 18:05:51
Before you do anything, inspect cab thoroughly for loose parts. Tighten or replace all loose bolts - don't forget lock washers/or other methods of fastening. Check all metal joints for broken welds, etc - fix as necessary. See that cab is firmly mounted and Fastened to chassis of machine. Loose parts vibrating can be worse than any outside sounds creeping in to the cab.
