1996 JD 955; Hydrostat creeps
Steve Denson
02-08-2005 07:14:13
Every since my tractor had approx; 200 hours the hydro started to creep on me. the problem seems to be getting worse. I seem to be hearing a slight whining noise like something is restricting fluid flow.When tractor is cold it takes a few seconds to engage. The tractor has right at 400 hrs. on it now.I changed the filter & fluid at 300 hrs. Any suggestion's. Someone told me there's a factory bulliton, but my local dealer seem's to no nothing about it.
Mike M
02-08-2005 08:58:58
 Re: 1996 JD 955; Hydrostat creeps in reply to Steve Denson, 02-08-2005 07:14:13
Did you clean the suction screen ? Did you use JD low vis hy gard ? I bought my 755 used so I don't know how noisy it was when new but it has 550 hrs and it whines alot,but seems to work good and responsive.There should be some adjustments to center the linkage.Did you lube up the linkage good and all the piviot points. Mine was sticking and this helped alot.
