4320 trade for 7020 Advice!
GJS
02-08-2005 02:05:00
We currently have two JD 4320"s. We really need a bigger tractor to cut down on the time spent in the field. I would love to find a 6030 or even a 7520. I ran across an elderly fellow who has a 7020 sitting by his house and he needs a smaller tractor. I will be going back to look over this tractor since I couldn"t when I initially found it. He mentioned the possible trade and I would probably throw in a disk with it to try to even out. The thing is I know our tractors are in very good conditioned well maintained. What should I look for in this model that could give me any hints of problems.
billyiron
02-09-2005 07:47:38
 Re: 4320 trade for 7020 Advice! in reply to GJS, 02-08-2005 02:05:00
I got a 6030,,,it aint cheap, how much you wanna spend,,,billy
GJS
02-08-2005 17:07:25
Thanks for the replies. I kind of had the feeling that our 4320"s may be the better of the two. I think I will continue loooking for a 6030. I passed on one a couple of years ago because my dad didn"t want to get that much horsepower. Mistake!
JD 5020 guy
02-08-2005 13:11:06
7020s sell for about $6,000 around here. I understand 4320s were only made for a few years. I would think the trade would already be even if not in your favor. Besides more drawbar hp and 4-wheel drive, the 7020 would have 16 speeds if equipped with the Hi-Lo option. One thing the 7020 does not have is a live PTO.
Loren-MN
02-08-2005 12:46:34
I've operated 4320, 4620, 4620-FWA, 7020, 7520, and many more later models. If going from a 4320 to a 7020, in my opinion, you ain't gonna like it. The 7020 will little if anything more than your 4320. When I had my choice, I'd run the 4320 over the 7020 any day. (Side note: Worked for a farmer that had all these tractors).
I'd keep looking for something at least in the 30 series generation.
JD 5020 guy
02-08-2005 13:00:09
 Re: 4320 trade for 7020 Advice! in reply to Loren-MN, 02-08-2005 12:46:34
Am I missing something here?? How does a 115 hp 4320 keep up with a 145 hp 4-wheel drive 7020?
ijl
02-08-2005 18:12:05
 Re: 4320 trade for 7020 Advice! in reply to JD 5020 guy, 02-08-2005 13:00:09
I had a 4320 for 13 years that was turned up to 150 HP and had no problems with it. It was the best tractor I ever owned. If it would of had a quiet cab I would still own it. My advise,keep your 4320.
msb
02-08-2005 08:45:15
How about a sharp 6030 with a Sound Gard body?New tires and duals.Its listed for sale at $17,000,but I have been told it could be bought for less.Its located in central Indiana(Wilkinson) at Swindell Farm Equip.,1/765/737/1030
Thats a lot of tractor and comfort for the money in my opinion.Ask for Joe.He is the owner.
BMAN
02-08-2005 06:55:25
A good 4320 is worth thousands more than a 7020.
wimpfarm
02-08-2005 06:44:52
Well you have the better of the deal already .
I"m not saying the 7020 is a bad tractor or anything but the 43 will bring more money almost any day easily so consider that . Check the bushings in the swivel area & drive shafts would be the main thing ,run it through the gears to see if they all work & check the axle bearings .There is allot of work working on these tractors as they have to be almost disassembled to do transmission or rear end work, the motor holds the front end in place making it the frame.
that means pulling motor for most any major work.
Terry....
