H heals itself!
Scott in SC
02-16-2004 04:39:05
I have a 42 H with a fresh engine rebuild. It suddenly stopped running last week for no apparent reason.I was about to ruin the starter trying to get it going. All it would do was backfire through the carb. It also seemed like the flywheel was harder to spin than it normally was. It would spin freely up to a point, and then get hard to turn. (This was with the spark plugs out) Decided this morning that I would try and pull start it. Pulled it about 10 feet, and it fired right up. Cranks and runs just fine again, and the flywheel spins easily again.What could have been the problem???
John T
02-16-2004 08:12:53
 Re: H heals itself! in reply to Scott in SC, 02-16-2004 04:39:05
Congratulations Scott, I rebuilt a JD once and had a machine shop do the valves. I think one may have been a tad tight cuz if it slow idled prolonged periods and didnt get much oil up in the valve area, one of the valves would get to hanging/sticking. That caused rough running and spitting back and she wouldnt re start with a stick of dynamite lol. It didnt ever happen if the RPM's were kicked up and used a lil harder. Excess cranking you did can get too much gas in the cylinders which washes off the oils ring sealing effect PLUS can wet gas foul the plugs. I believe I would run a top cylinder lubricant like Marvel in the crankcase, use a lighter grade of multi viscosity oil, maybe a small can of 2 cycle engine oil in the gas, a fresh set of plugs, and use the old girl under some load at temperature and avoid prolonged idle periods a while and the problem may never re occur?????
Good Luck n God Bless
John T
Scott in SC
02-16-2004 08:34:17
 Re: Re: H heals itself! in reply to John T, 02-16-2004 08:12:53
Thanks, guys. I wish all my problems worked themselves out this well.
Clooney
02-16-2004 06:37:28
Scott, you probably just washed all the lubricating engine oil off the cylinder walls from all that cranking & trying to start it.. Once it started it re-lubricated the cylinder walls & all is good..
~Either that or you had a sticking valve & it freed up after pull starting & getting some oil flow to it.. [I'm betting on a dry cylinder walls though]..
~You might want to give the crankcase oil a sniff as it could be polluted with gasoline by now.. If you smell a strong odor of gasoline in the oil, change it..
[email protected]
Russ
02-17-2004 03:21:56
 Re: Re: H heals itself! in reply to Clooney , 02-16-2004 06:37:28
H LUBE MIRACLE; DRAIN YOUR ENGINE OIL COMPLETELY AND PUT IN FRESH OIL. YOU NOW HAVE BAR OIL FOR YOUR CHAINSAW OR GENERAL PURPOSE OIL FOR EVERYTHING ELSE. IF YOUR H SPARK PLUGS ARE CLEAN AND DRY IT SHOULD START WITHIN 2 OR 3 SPINS. ENJOY THE H IT IS A LOT OF FUN TO RUN. GOOD LUCK.
