60's transmission HELP
BIG JAKE
02-07-2005 15:59:57
Yesterday my son got my 1952 "60" stuck in or between two gears he was shifting from reverse to second when the tractor locked up. I worked with the tractor shifter and clutch until it jumped into second gear, the tractor started pulling alright in all gears but it is making a grinding noise when you ingage the clutch in netural the noise is not as bad when I put pressure on the clutch lever the noise seems to go away. Can any one help me please thanks BIG JAKE
BushogPapa
02-08-2005 07:32:06
 Re: 60's transmission HELP in reply to BIG JAKE , 02-07-2005 15:59:57
You have a problem in the clutch that "Clooney" has addressed in here before.. The information should be here un the "Achives".. If the 60 has been doing this much at all, you will need to lift the shift quadrant/steering tower off, and look at the shift forks and shift lever for wear... Always check to see that the bolts are tight that hold the shift lever in place ( from under side)..you can ONLY tighten them with the shift tower OFF..!! Could be a combination of wear, and weak "detent springs" on the shifter shafts..
