I'm looking for the same thing ... here's what I found so far: "John Deere never puts schematics in operator's manuals (considered dealer work).""$90 or so for the repair manual" "Two 12V batts connected to make 24V for the starting while the lights and guages are set up for 12V. That's why if it's set up wrong, one can kill one battery running the lights.... I think the converstion is still available from Deere, but last I asked price (years ago), it was like $350 +. Complete kit though, new starter, Alternator, wiring harness and so forth.." "The way I have had it explained to me is that your tractor was manufactured with two 12 volt batteries, one with it`s positive terminal grounded to the tractor frame and the other with it`s negative terminal grounded to the frame. I have had it explained that some of the accessories are operated off one battery while other accessories are operated off the other. The most voltage available anywhere on the tractor between any ground point and any wire is 12 volts. However, there are wires that are + with respect to ground and there are wires that are - with respect to ground. The voltage between the + wires and the - wires is 24 volts that the starter sees when cranking. Presently, your charging system must supply 12 volts positive to one battery and 12 volts negative to the other battery at the same time. The way it has been explained to me is that there are two options. If you must keep the 24 volt starter motor, then you will have to obtain a 24 volt alternator. This is what you are already contemplating. The alternator must provide both +12 volt and -12 volt with respect to tractor frame ground. More often than not, folks will opt for changing to a 12 volt starter, then using regular 12 volt automotive alternators. If you opt for the 24 volt system, you will have additional problems of providing 12 volts to the accessories, all their load will be on one of your two batteries and none on the other. If I recall, at one time, John Deere offered a kit to convert these tractors over to 12 volts, not sure if they are still available, maybe someone else here can help with that. Interestingly, one fella I asked about this said the best solution was to keep the tractor stock."
