720 pony won't start
Blane
02-07-2005 13:57:35
Hello, I am having some difficulty getting the pony on my 720 to start. I replaced the coils and the pony still wouldn't fire. So I checked the point clearance and it was okay, but then when I was checking the plugs by letting the pony crank, the wire that goes to the distributor box started to boil and was extremely hot to the touch. So I took that wire off and replaced it with another wire and then when I tried again the button wouldn't roll the pony over so I looked wires over and started to replace other wires and still can't get the pony to start and I'm not sure if there is any juice getting into the distributor box. Please help if you have any idea what I am missing, I also replaced the push button and the solonoid on the top of the starter just in case those were causing problems.
buickanddeere
02-08-2005 07:42:17
 Re: 720 pony won't start in reply to Blane, 02-07-2005 13:57:35
Blane, before we go much farther. Do you have a wiring diagram to work from and a muiltimeter? Kind of difficult to explain a nest of wires with words. I've seen the terminal on the side of the cranking engine ignition box short to the metal box. Makes for a pinned ammeter and a warm bunch of wires. That post on the side of the ignition box is supposed to be a junction post that floats isolated from ground/chassis.
Blane
02-08-2005 10:12:17
 Re: 720 pony won't start in reply to buickanddeere, 02-08-2005 07:42:17
I have a volt meter and the wire diagram. I think we have about located the problem, when I took one wire off one of the points the engine rolled over and fired on 1 and 3 pistons so I think the one coil is bad and the other is okay, I must have scratched the lining off of that coil, I haven't taken it off yet but I will to make sure. I hope that is the problem.
Emerald70D
02-07-2005 17:48:45
Blane... when you removed the old coils from the center coil bar did you have to "persuade" it with a hammer?? If you hammer on the end of that soft coil bar it will mushroom it and when you slide the new coils on the now sharp edges of the bar will peel the insulation off inside of the square hole, exposing the coil windings directly to the center bar causing a dead short. That's about the only way the lead wire going to the terminal poast in the upper left corner of the coil box can get that hot.
Blane
02-07-2005 20:08:53
 Re: 720 pony won't start in reply to Emerald70D, 02-07-2005 17:48:45
I used a hammer to tap the bar down, I guess that they might be sharper than they should be. I didn't know the inside insulation was that thin. I suppose that means I would need new coils and a bar. Can you get the bar?
F-I-T
02-08-2005 14:07:02
 Re: 720 pony won't start in reply to Blane, 02-07-2005 20:08:53
Blane:
You should be able to check from one of the coil leads to the bar to detect a short, though it sounds like you"ve isolated the problem.
Frank
Blane
02-08-2005 16:19:54
 Re: 720 pony won't start in reply to F-I-T, 02-08-2005 14:07:02
I took the bar with the couls off and turned it around so the coils were running the opposite plugs and the pony started and ran on all the cylinders. I'm very happy but I don't really understand what was wrong unless when I put the screws back in I grounded what wasn't grounding?
Emerald70D
02-08-2005 07:15:27
Blane...the bar is still available from JD, but not cheap. Remove the new coils from the existing bar and check out the coils to see if there is exposed copper wire inside the square holes where the bar slides through the coils. If you do, that's your short.
Blane
02-08-2005 07:18:40
 Re: 720 pony won't start in reply to Emerald70D, 02-08-2005 07:15:27
Thanks
mike brown
02-07-2005 16:04:27
If the wire to the distributor got that hot it must have had a dead short some where. Hopefully not through your new coils! I had a 720D a few years ago and had my share of gremlins in the pony ignition. After a couple of sets of coils I gave up on them and bought six volt canister coils (4) and mounted them on a bracket up under the hood out of sight. I used wire core spark plug wire to wire them to the points in the ditributor, then from the output of the coils to the plugs. This may make the purists cringe but it looked stock and started great from then on.
Get a tester and trace the current paths. You may have roasted the coils when that wire got hot.
Blane
02-07-2005 16:18:00
 Re: 720 pony won't start in reply to mike brown, 02-07-2005 16:04:27
I hope not those coils are expensive. How much did all of that stuff cost, would it be cheaper than getting more coils. Thanks
mike brown
02-08-2005 04:28:02
 Re: 720 pony won't start in reply to Blane, 02-07-2005 16:18:00
Blane;
the pony coils are expensive, the canister types I got at a tractor bone yard for a few bucks apiece.
F-I-T
02-07-2005 16:52:53
Blane:
Those coils tend to run around $55 ea for the foreign made ones, and more for the domestic version.
It sounds like you'll need to trace all of the wiring before you buy any other expensive components. Without a wiring diagram, it will be difficult.
Basically, a wire will run from the switch mounted resistor and that will run to the distributor lug. Another wire will run from the solenoid to the lug and this will supply 6 volts direct to the distributor during cranking only.
If one set of point were closed and you let it set there with the switch on for any length of time, the wire could get very hot and probably ruin the coil.
As to why the push button is not firing the solenoid, that can be checked using the appropriate jumper wires to make the solenoid fire.
If you have a parts book, there is a rudimentary wiring diagram in there. While it may not be exact, it should get you running.
Did it ever run? Or are you trying to resurrect a dead pony?
Frank
Blane
02-07-2005 20:16:14
 Re: 720 pony won't start in reply to F-I-T, 02-07-2005 16:52:53
This is my main field work tractor and I replaced the coils about 5 years ago and over the summer they were getting weaker and weaker until the engine wouldn't start, so I ordered new coils and put them on and that is when all this trouble started, the tractor only sat for about 3 weeks from the time the pony started itself to today when I can't get it to start with the new coils. I have replaced a lot of the wiring behind the dash, all the wires that go to the push button and the push button and solonoid themselves, mainly because I have been getting pretty frustrated. Thanks.
Soldier Tom
02-08-2005 15:50:12
 Re: 720 pony won't start in reply to Blane, 02-07-2005 20:16:14
Forgive my oversimplistic thinking, Im overly simple sometimes. On my 720d, the pony won't start with a weak battery, it will spin over, but not fire. I can't leave the battery hooked up or it will drain out in a couple or three days. Just a thought, could a fresh charge on the battery make a difference? especially since the short? Again, I am new to this, VERY new.
~Walk in peace~
Soldier Tom
F-I-T
02-09-2005 16:15:43
 Re: 720 pony won't start in reply to Soldier Tom, 02-08-2005 15:50:12
ST:
If you want to find that battery drain, I'd be happy to recount my "Electric Leak Detector" circuit.....It never fails.
Frank
Soldier Tom
02-11-2005 16:32:29
 Re: 720 pony won't start in reply to F-I-T, 02-09-2005 16:15:43
Frank, I'd like that. Thanks. I got a long way to make a show tractor out of it, or a worker for that matter, but I am VERY open and willing to fix things as I can along the way. We put your circuit breaker on the pony after we put it back together, along with a pony oil pressure guage mounted under the starting levers to keep an eye on the pressure.
My email is posted, thanks Frank for all your help so far. ~Walk in peace~
Soldier Tom
buickanddeere
02-09-2005 02:00:19
That sounds like the bypass circuit for the cranking engine ignition maybe open while cranking? The coil voltage is too low to fire the plugs due to voltage drop during cranking and feeding cuurent through the ballast. Or it could be a simple as a good looking cable/connection that is hidding a voltage drop.
Blane
02-08-2005 16:15:14
Thankyou, I will try to do that to, the battery is pretty new but I'll charge it up. Thanks
buickanddeere
02-08-2005 00:28:13
If the coil's ballast resisitor was accidentaly bypassed. That could also explain over heated coils and burned off wires.
Blane
02-08-2005 07:20:16
 Re: 720 pony won't start in reply to buickanddeere, 02-08-2005 00:28:13
What is the ballast resistor?
buickanddeere
02-08-2005 07:32:42
 Re: 720 pony won't start in reply to Blane, 02-08-2005 07:20:16
Cranking engine ignition coils get direct full electrical system voltage. While the cranking engine is being rolled over by it's own electric starter motor. When the cranking engine's electric starter is released the ignition coils are now fed in series with a ballast resisitor that limits voltage entering the ignition box to about 4.5V when both points are closed. If the ballast is not used, the smoke will leak out of the coil's primary electrical wire windings.
