51JD B
chadman
02-07-2005 09:13:23
tring to get gas tank off so I can emtpy all the rust and dirt out of it (thought about sucking it out with shop-vac but doesn"t sound to safe) appeiceate any help thanks :)
jdhbag
02-07-2005 16:49:39
 Re: 51JD B in reply to chadman, 02-07-2005 09:13:23
Use a pint of bolts and nuts, then you can fish them out with a magnet. I strapped my tank to the wheel of another tractor that was jacked off the ground in the rear and let it idle in gear for a few hours. Worked great.
ChuckW
02-07-2005 09:31:30
when you get it off you can put some clean rocks or gravel and shake around to clean out the rust. will be a two man job with all the sheetmetal but it works.
jd b guy
02-07-2005 15:38:28
 Re: 51JD B in reply to ChuckW, 02-07-2005 09:31:30
Yeah, I did the rock thing a while back.
#1 - make sure you use fairly large rocks (1/2" - 3/4"
#2 - Make sure you wash the rocks before you use them.
I didn't do either and ended up with some small rocks in there and a lot of "rock dust" -- Took forever to get them all out and really get all the dust out.
