G Clutch
Steve from New
02-07-2005 04:31:22
I need advice on a G clutch issue. (s.n. 23124) The clutch engagement and disengagemnet feels very "spongy" for lack of a better word. I have renewed or rebushed all external linkage pivot points. The linings are all new. And yet, when you go to engage or disengage the clutch, the handle travels much too far before the action happens. I cannot tighten the clutch very much or I cannot even engage the clutch because I run out of handle travel before it snaps into engagement. I currently have the internal parts totally disassembled. The toggles, dogs, and operating sleeve appear to be ok, but I must admit I do not know the specs of the "socket" holes to know if they are worn or not. Nothing seems to be cracked or broken. Any suggestions would be most welcome. Thanks a bunch, Steve
Jak
02-07-2005 06:28:39
 Re: G Clutch in reply to Steve from New Holland, 02-07-2005 04:31:22
The dogs and toggles can be worn quite a bit and you can't tell it just by looking at them.But if you have new ones to compare them to you will see it then,got the t-shirt.
02-07-2005 04:33:51
Buy the way, I did clean up all parts including the pulley assembly so dirt and grime is not an issue. Thanks, Steve
Unknown Puller
02-07-2005 08:49:51
 Re: G Clutch in reply to Steve from New Holland, 02-07-2005 04:33:51
A friend of mine had clutch problems on his G puller close to what you describe. After doing all you have done plus more, he finally found his trouble. The splined shaft (F198R) that moves the fork had a hair-line crack in it, which allowed it to flex and not move the fork as it should. Very minor adjustments caused the clutch to either slip after it snapped in or not be able to disengage after it snapped in. The shaft would have completely broken over time, but the flexing was what was causing his problem. He had it apart several times before the hair-line crack was spotted.
Goodwrench
02-07-2005 12:23:29
 Re: G Clutch in reply to Unknown Puller, 02-07-2005 08:49:51
Had the exact same problem a few years back. Good idea to review these parts during process (shaft & splined casting)
Jak
02-07-2005 10:32:38
I had a 52 G that splintered that shaft your talking about.Dengler was real proud of thiers but I had to have one.
02-08-2005 04:21:29
 Re: G Clutch in reply to Jak, 02-07-2005 10:32:38
Thank you all for your help. I will look into those 2 items. Steve
