Rear Tires
Ken in Mich
02-05-2005 19:25:48
I am going to need rear tires before to long. Where do you get them: JD dealer, farm supply, tire store etc? Do you mount them yourself, have someone come out to do it, or pull the rims and take them in?
The tires in question are 18.4-28, the ones on the tractor now are 10 ply, I see in the manual the spects say 6 ply, on a JD 500A backhoe. Thanks, Ken
Roy Suomi
02-05-2005 20:56:32
 Re: Rear Tires in reply to Ken in Mich, 02-05-2005 19:25:48
You already have a bead breaker.. It's called a bachoe rear bucket. Lay down the tire and press down with bucket teeth close to rim, then pry off tire using tire irons. [ not screw-drivers] Lube new tire with murpheys oil soap and pry it on with tire irons. stand tire/wheel up and air it up,using no more than 30 lbs to seat bead. [ cheap insurance is to wrap a chain loosley around tire/rim so it doesn't accidently pop over rim..]
Gerald J.
02-05-2005 19:35:26
JD dealer might have them but most likely you need a farm tire dealer. It is not impossible to change them yourself but you need a really good bead breaker that can cost several times the price of having the dealer come to you. Those 10 ply tires are going to be hard to move.
Most farm tire dealers around here have specialized trucks for changing tires while the rims are on the tractor (that's easier handling than working with the rim flat on the ground when the tire weighs a couple hundred pounds). One I've dealt with uses the same truck (with its engine driven compressor) whether on the farm or at their shop. Another dealer quoted me $25 less if I bring the tractor to his shop so he doesn't have to put the wear on his truck engine.
I've watched two sets of 28" tires changed. Both times the old ones were old and stiff, one set was two sizes too wide and gray. Those doing it earned their pay and I watched and concluded the price of admission to watch was well worth the price. The last set cost $90 for labor and that included pumping out calcium chloride solution (I didn't put it back) and maybe a couple tubes. I bought the tires some other tire store at that time because of where the tire went flat.
I'll be looking at some bigger tires soon and I'm sure that I AM NOT going to do the changing. I might change the rims (will have to since I'm going from 18.4-34 to 16.9-38) but I think it will be handy to have help with those too.
Where are you located?
Gerald J.
