2520 Wont Quit
Brad S
02-05-2005 19:15:30
My John Deere 2520 diesel will not shut off, Key switch seems to work,If you pull the wire off the injector pump it still keeps running, any ideas,Thanks
Mike M
02-07-2005 10:39:17
 Re: 2520 Wont Quit in reply to Brad S, 02-05-2005 19:15:30
I guess you should feel like the lucky one as most posts here they can't get their tractors to run. LOL
jdemaris
02-05-2005 19:41:55
Does it have the CB pump or the JDB pump? CB has a wire on the side that pulls straight off. JDB has a wire that is held on by a nut. If you have the CB pump, the shut-off plunger is probably hanging up, that's common. If you take the solenoid out - you can use dual flatheaded screwdrivers to do it, unscrew it counterclockwise. You will find it has a little spring loaded piston in it. That piston has to move back and forth freely. Spring pressure forces it to closed position to shut the engine off. When 12 volts is applied, the piston pushes against the spring for the engine to run. So, you might just have to clean up the piston bore a little. Be care not to lose the little spring - it's about the size of what you'd find inside a ball-point pen. Also make sure the little piston still has its rubber seal on the end of it. If you have the JDB pump, with the solenoid inside the top cover, repost and I'll explain what to do. There is some linkage to look at and a clip that might have fallen off.
Brad S
02-06-2005 09:34:15
 Re: 2520 Wont Quit in reply to jdemaris, 02-05-2005 19:41:55
Thanks for the info, It is a cb pump, I cleaned the bore and piston and it only works occasionally, Is this part available? Thanks again, Brad
jdemaris
02-06-2005 10:49:29
 Re: 2520 Wont Quit in reply to Brad S , 02-06-2005 09:34:15
Last time I checked it was availalbe, but it's probably not cheap. Most parts for the C series pumps were phased out back in the early 80s. Common wear items like the shut-off solenoid, seal kit, and throttle-gear set WERE kept in production, but if a major part failed - a kit was used to change the entire pump over to a DB series. Any good injection pump dealer can help out. About your solenoid, the original ones had a metal bore where the plunger rides in and out. The newer ones have a soft lining, looks like some sort of plastic. They seem to work better. If, for some reason, you can't find one - repost. I probably have a few laying around in my injection parts junkbox.
