3 Point Hitch
New To Green
02-05-2005 16:47:00
Do they make a 3 point hitch for a 52 B, also would anyone recommend putting said hitch on tractor?
Thanks for your time.
New to Green
Mike M
02-07-2005 10:33:04
 Re: 3 Point Hitch in reply to New To Green, 02-05-2005 16:47:00
If you make a 3 pt. you better go ahead and make a weight bracket for the front end too as these are a bit light on the front. A JD 800 series hitch works good on these the arms on the aftermarket hitches are usually longer makeing the light front end problem worse but both will work fine just ballast the front end accordingly.
dbwillia
02-06-2005 12:00:18
I have a 3 point hitch on a 1948 B John Deere. I used an 8N Ford for pattern for the width and height and purchased 8N lift arms from a local farm supply store. I have used it for 3 point blade, dirt bucket, and lift boom pole. Also a small three point tandem disc. It makes the tractor more versatile and with a little care you will have no problems. Would hate to go back to not having a three point. HTH
Richard H.Gambrell
02-06-2005 10:33:26
Look at the implement photos on the left of this site and you will see two photos of my hitch.
mitchp
02-06-2005 09:40:49
try www.tonystractors.com they have a 3 point hitch that works quite nicely. easy on and off and not a bad price
JDVan
02-05-2005 22:36:40
JD did not offer a three point hitch option for the 52 B when they wre originally made. In late 1953 JD announced the 800 Hitch for the 50, 60 and 70 tractors and also the G. JD did not recommend using the 800 hitch on the A & B, however within reason it will work quite nicely. A couple of the resons that JD did not recommend using the 800 hitch on the A & B was that the newer Pressed Steel frame caused the tractor to be quite light in the FE and the hydraulic lift capacity wasn't quite up to par for some implements. The G still had the cast frame and was heavier in the FE.
Later in 1955 the 800 hitch was replaced by the 800 A and also another hitch was announced called the 801 Hitch. All will work on your 1952 B if used rationally.
I have quite a bit of info on 800 series hitches at and have some for sale:
Link
Hayfarmer
02-05-2005 18:13:11
There are at least a couple options for a 3 point. Assuming you have power trol, you could use a JD 800 or 801 hitch if you can find one. Won't be cheap. Next option would be after market, there are several manufactures that make them including Saginaw and Worksaver. Couldn't tell ya more about either as I have never used one on a B. The B is a bit light on the front end to lift some 3 point equipment, on the other hand it definitely makes it more versitle so I guess it depends upon what you want to do with it. If tyou have power lift instead of power trol then it is either all up or all down.
