I wonder how much actual water would be the result of an inch of snow falling on the open tank neck? If that's the only moisture that got in (in other words is the tank was not open outside of that one snowfall), I wouldn't think it would amount to much. If it is a working tractor, and you could get it in a warm place to thaw, and drain some fuel out to see if there's any water in the bottom, and then add some diesel fuel conditioner (that's labelled to disperse water) to the next couple of tankfulls of fuel, and then change the filter, you'd probably be alright. I would be even more worried about a tractor that dosen't get used much, so not much fuel is run through it, and it sits idle most of the time, so any moisture will stay in the system, and corrode the pump, tank, and injectors. I guess if there's noticable water in the bottom of the tank, I'd probably take it off, pour a bottle of the previously mentioned conditioner in the tank, swish it around, dump it out of the tank, and repeat a time or two. That would be a lot of work, but could save some very costly repairs later!
