A or G whats the diff
tugboat timA or
02-05-2005 06:25:26
A friend of mine bought a jd the decals say A but the engine looks massive i think it's a G instead of an a whats a sure fire way to tell them a part
The Rodent
02-05-2005 09:22:25
 Re: A or G whats the diff in reply to tugboat timA or G, 02-05-2005 06:25:26
Just look at the frame toward the front of the tractor. If it is strait it is a A, if it has a bend in it, it is a G.
Pat Browning
02-05-2005 07:48:11
Check the frame along the engine toward the front of the tractor. For Model A, it is a straight run. For Model G, it is wider to go around the engine, then narrowing at the front. The frame for both tractors was the same width at the front so as to mount implements like a cultivator. (PatB)
730-LP
02-05-2005 07:43:13
If it has a serial # tag it will have the modle on it, unstyled tractors tag is behind the flywheel,styled tractors the tag is above the belt pull on the right If it has no tag the G casting # will begin with F if its an A the casting # will begin with an A
Mark Scholten
02-05-2005 07:42:44
I think the easiest way to tell the difference between an "A" and a "G" are the air and exhaust stacks. An "A" has them in line and a "G" has them on opposite sides of the hood.
No serial number? If so, it will start with the model.
Mark
T213R
02-05-2005 07:06:02
Is this a Styled tractor or not? You mention decals. What decals specificlly?
For a styled tractor, especially a late styled tractor, the differences are dramatic. Or an unstyled tractor, it's a little harder to tell!
