2 cylinder transmission oil
Randy Stoudt
02-04-2005 15:00:15
I have used a few two cylinders over the years. (A,AR,H,B,60,720) None of these transmissions ever shifted as nice as Dads old G on the farm. Well when I seen at a tractor show that the 70 had the same 2 lever transmission my quest had begun to buy the ultimate two cylinder. Well I bought one but it just don't have that silky shifting like Dads G. How will motor oil work in the transmiision? With it holding gallons of oil I did not want to experiment very much.
John in IN
02-04-2005 19:19:44
 Re: 2 cylinder transmission oil in reply to Randy Stoudt, 02-04-2005 15:00:15
I use 140 Wt. GL-1 in my unstyled tractors and 90 Wt. GL-1 in the later moddels. GL-1 should be used in older equipment as it does not have the additives that will atack the bronse and brass parts. The Chevron Internet site has a section on this and explains it well.
buickanddeere
02-05-2005 12:25:20
 Re: 2 cylinder transmission oil in reply to John in IN, 02-04-2005 19:19:44
The marine oil is a higher pressure oil but resisits corrosion as it's made to still lube and protect while mixed with water from leaking seals.
buickanddeere
02-04-2005 15:11:41
GL-4 Marine 140 weight leaks slower than thinner oil.
