3020 vs 2020 gas consumption
mgb
02-04-2005 07:42:26
I read on a post on here that the 3020 gasoline uses between 5 and 7 gallons per hour under load. I was wondering if anyone had the statistics for a 2020 gas row-crop utility.
bucianddeere
02-04-2005 15:17:43
 Re: 3020 vs 2020 gas consumption in reply to mgb, 02-04-2005 07:42:26
1969 3020 gas syncro 71.37 pto HP at 10.91 HP per gallon per hour. 2020 gasser 53.91HP and 11.17 HP per gallon per hour. Those engines were likely tuned for peak HP instead of peak efficency.
Bill-NNY
02-04-2005 21:30:40
 Re: 3020 vs 2020 gas consumption in reply to bucianddeere, 02-04-2005 15:17:43
I used the 1966 3020 test info and came up with the 3020 at 71 hp rated for 10.66 hp-hrs per gal burning 6.6 gallons per hour. This is for full load.
the 2020 was 54 hp at 11.17 hp-hrs per gal burning 4.8 gallons per hour. This was for full continous load.
These numbers are based on new tractors operating under standard condition at Neb Test Lab.
Condition of the tractor and the type of load will change the consumption rates. So these numbers will give you an idea how "thirsty" these can be.
Bill
